I have a problem with the penetration holes for my throttle and carb heat (RV-9A, O-320). I haven't yet drilled these holes. Earlier I moved my fuel pump firewall doubler up a bit so the nutplates wouldn't interfere with the engine mount. Now the plate is making it impossible to put the throttle and carb heat cables where vans says (I have the FF Kit).
Moving the doubler plate again at this point would be extremely difficult (engine hung).
Question - if I raise the throttle cable penetration hole by .5 inches and the carb heat cable penetration hole by .75 inches, will this be OK? Will the supplied cables still work?
