tx_jayhawk
Hi All,
I am installing my control cables (throttle, mixture, etc.) for the last time. The instructions have you put a SB500-6 snap busing in the fuel pump cover that the cable goes through. Although the cable easily fits in that size, the threaded metal portion (that the jam nuts attach to) is bigger than the ID of the specified snap bushing. Going to a larger size would make the cable fairly loose in the bushing.
Have others just slit the bushing or grommet, or done something else? Plans don't seem to address.
Scott
7A
Scott
7A
