pmccoy
I am thinking about wiring my wings, and have searched and read a few threads on making wire connections at the wing root. It seems people are using AMP CPC connectors, terminal strips, molex and more. I am also considering wiring in a connector at the back of each side of my removable panel. That would allow me to pull the panel for maintenance going forward.
Several of the connections in my wings do require a small amount of power to drive lights and servos. No circuit is more the 4.5 amps, but all totaled up it could be as much as 11amps if everything was on at the same time.
Looking at CPC, the spec sheet say's this is for signal wire only. No power.
Molex allows power, but I have been told are not good if you plan to plug and unplug more then just a few times, which shouldn't be a problem in the wing root.... but makes me wonder on the panel option.
Terminal strips seem to allow open electrical connections that run the risk of having a conductive object get inside the cover and possibly shorting out a circuit.
Yikes, what's a builder to do??
Any ideas on how to make wing root connections would be appreciated. Thanks.
