tomhanaway
For those that installed pilot and passenger throttle controls, what did you use for the connection between the two systems.
Straight steel rod connection?
Cables?
Tom H.
Here's a picture of the linkage rod between the passenger and pilot throttles ...
I used thick wall steel tubing, the ID was slightly smaller than the tap drill needed for the end links. Sorry I cannot remember the OD. Working well so far...
I had a local shop make a cable, basically a shorter version of the throttle and mixture cables. It works really well. The only thing I've found is it never gets used. If someone is flying from the back seat I usually manage the throttle because the passenger can't see the engine monitor.
