alpinelakespilot2000
Very basic wiring/resource question.
I've read everything I can find on the subject... Nuckoll's, Vans, Bingelis books and articles in EAA archives, and AC43.13b. No luck. I'm looking for something that describes in detail the different ways one can connect wires to each other. Most describe one or two methods for normal situations (e.g. one wire to one wire), but don't go into any depth on more complex connections. As a consequence, you don't learn which method is best or for what situations. Likewise, Nuckoll's is good on theory but very light on application. Are there any other sources I've not yet found?
The question that prompted this:
My Nav light circuit will eventually have 5 major wires (not including the grounds, of course):
1. Red wing light
2. Green wing light
3. White tail light
4. Map dimmer light (since they don't turn off completely, dimmers will only be on when Nav lights are also on)
5. Glareshield dimmer light
Downstream of the nav light switch (I'm using B&C with fast-ons), how do I get all 5 wires together? I've seen a couple options:
1. Use more than one wire in a fast-on terminal. Bingelis shows this in a Sport Aviation article, but doesn't say how many wires one can get away with or what size terminal must be used. What are the rules here? How many wires can go in one terminal and what size does the terminal have to be?
2. SteinAir provided me with a a few "piggyback" fast-on terminals. This would help me with one or two of the wires, but 5?
3. A terminal block with as many jumpers as necessary to connect all wires. Awkward to locate, and takes up a lot of space.
What makes the most sense--any of the above options or something completley different?
Also, where would be the most logical place at which the first three wires (red, green, white) break off from each other? Right at the switch or somewhere aft of the spar box?
Again, though, so I don't have to ask more of what seem to be dumb questions, anyone have a good source?
1. Red wing light
2. Green wing light
3. White tail light
