constantin_w
I'm New Here
Hi guys,
we have replaced our old garmin unit in our RV-12 (old ULS version) a while ago. Works fine with the AP74. In parallel, we are using an iPad with Skydemon and so far a Stratux which is connected to the iPad. Unfortunately, the double connection from Stratux to the iPad and further on to my Headset is far from perfect and hence, I am looking for a solid and continuous solution built into the aircraft.
Not, I would like to use the existing screens and avoid any other screens.
Is it possible to connect the TRX-1500 to the Aera660? Is there a chance to also connect the iPad via Wifi to the TRX so that traffic is being sidplayed on both devices? Will there be an audio warning on the Aera 660 in this case?
Sorry for the amount of stupid questions! Looking forward to your answers!
BR
Constantin
The TRX1500 has 3 outputs, I have one to an air connect (SD on a tablet) and another to a FLARM View. Should be possible to do what you describe.
