My email to "[email protected]" no longer goes through, so I tried their web based email thingy, but maybe folks here have done something similar:
I'm trying to ask the G3X guys how I should connect a "Van's Aircraft stall warning tone generator" to the GMA audio system? Van's instructions say basically - connect to the audio system. Not very helpful - since the diagram only shows the single line out from the board to connect to whatever. The Garmin manual shows all audio alert sources coming in pairs - hi and lo. So do I connect the "lo" feed to the ground at the tone generator board?
I don't want to blow out the GMA, and I saw others remark that the stall warning is pretty loud when fed straight into the headset - some use a resistor to tone it down. Might just leave it unconnected and use the AOA info from the G3X.
