PittsCondor
I'm know this is an old topic but I can't seem to get my 796 to communicate with my GRT HX. Looking for any advice that might help.
I have the Orange Serial 2 wire from the 796 wired to Serial 7 in on the HX. I selected the NMEA format and speed normal.
I'm not sure what baud rate the 796 uses. When I hit the ? mark on the 796 it says 4800 baud is used. When I read some online posts looks like 9600 might be the answer. I have tried both with no luck.
Do I need to ground the Serial 2 in on the 796? I don't think this should matter.
I have this setup to be GPS2 in the HX.
Any suggestions on how I might get this to work?
Thanks.
Thanks.
