RV4er Well Known Member Jun 8, 2007 #1 My upper brake line is the paraflex tubing and I need to couple it to aluminum tubing starting at my upper gear leg. Any ideas? I can flair the paraflex tubing but I'm not sure it will hold up under the pressure.
robertahegy Moderator/Tech Counselor Jun 8, 2007 #2 Use two fittings that each correctly attach to the respective tube and have one convert to male pipe and the other to female pipe and just screw them together. If you can only find fittings that are male pipe, use a connector. Roberta
