I bought an old O-320 Lycoming and when I went to bolt up to the conical engine mount a clearance issue became evident.
I'm pretty sure this is an old motor as there is no suffix on the data plate and I believe it to be off a Supercub or a Tripacer.
The intake pipes prevent the bottom mounts from bolting up tight on my RV6A. HELP!
