danielhv
Ok. So I admit. It took me probably 4 months to do one fuel tank. And after that 2 of those 4 months, I just quit looking at the plans, and just built it. Everything went fine. *ahem* except one thing. I "forgot" (forgot to NOT get in a hurry) to dip the rivets for the skin to rear baffle in proseal. I did however, get a good bead on the inside where the baffle sits like the plans call for. And I did coat all the shop heads and seam with proseal to ensure there is no leak.
Well, I pressure tested today, and it went much better than it could have. I have 3 rivets leaking. And they are on the skin to rear baffle rivets. So here are the ideas I came up with:
1. Drill out the 3 rivets, drop some proseal in, and re-rivet. (only fear is disturbing the bead on the inside or lodging metal chips betweek the skin and baffle.
2. Try the whole vacuum the tank and suck proseal in through the 3 rivets. (Kinda confused on that one... if I suck it into one rivet, and pull a vacuum again to do the other 2, would the first one I did suck air and not seal. Here's some pics:
![img_3088.jpg](/community/proxy.php?image=http%3A%2F%2Fdanielhv.com%2Fwordpress%2Fwp-content%2Fuploads%2F2009%2F02%2Fimg_3088.jpg&hash=0d168f46da04bb9d433159432bd4c70a)
![img_3094.jpg](/community/proxy.php?image=http%3A%2F%2Fdanielhv.com%2Fwordpress%2Fwp-content%2Fuploads%2F2009%2F02%2Fimg_3094.jpg&hash=47f2bca7dfa9d1a45bda8aaa64b2d508)
