Is a compass required for airworthiness certification?
The FARs require a "magnetic direction indicator." The Dynon EFIS box has that. Is a seperate / conventional compass still required?
VFR only - obviously.
The Dynon meets the requirement for IFR. There are some inspectors that question this, but it meets the definition in the regs.I never found anything other than a "magnetic direction indicator"..even for IFR..
Am I wrong here..i never did fit a compass.
Frank
yeah, We've got a Garmin in there too - Doesn't everybody? Both it and the Dynon point north automatically.
For my inspection I Velcro'ed a compass to the glair shield
True but I would rather the GPS continue to work than have to try and figure out where I am with just a compass.They tell you the direction the aircraft is traveling, but not which way it is pointing.
From a practical stand point they are great, but technically they are not a "magnetic direction indicator".
A friend with a Sonex just got his pink slip using the same compass.When I built my Moni motorglider, the kit came with flight instruments. The included compass was a $1.99 unit from WalMart on a suction cup. It met the regs!
