Hey folks,
Over the past few weeks, with the temperatures dipping into the 20's overnight, I've been searching for best practices on starting my O-360 with the morning temperatures below freezing. The new and improved technique, is the following:
1. Mixture rich
2. Throttle 1/4 to 1/2 inch
3. Fuel pump on to normal fuel pressure then off
Warm Weather Steps:
4. Throttle push forward two or three times to squirt some fuel and back to 1/4 inch.
5. Mash the start button
New and Improved Cold Weather Steps:
4: Throttle push forward two or three times to squirt some fuel and back to FULLY CLOSED.
5. Mash the start button and pump the throttle with quick motion between FULLY CLOSED and 1/4 inch.
Engine starts in just a few compression strokes, amazing.
A colleague of mine gave me this technique, the idea being that modulating the carburetor butterfly valve between fully closed and slightly open, creates just enough turbulent airflow to vaporize the cold fuel.
I had searched Lycoming reprints, VAF, SACRANCH and the "interweb" thing w/out finding any help. The best I could find was verbiage saying the critical factor was getting the right fuel/air ratio, duh....
Works for me anyway...two days in a row...temps around 25 at night, 28-30 in the morning...
NOTES:
* I do not have an engine prime lever
* Without the rapid throttle motion on start, it would take three, five to eight second starter cranks to get the engine started on a cold morning
* Warm weather starting is always on the first or second compression stroke
1. Mixture rich
Warm Weather Steps:
NOTES:
