RonRV8
Member
Does anyone else have cold air leakage coming in from the small openings in the F-804N-1 Bulkhead Cap which is located just about mid thigh for the pilot? It seems to me that there must be a passage that is allowing air to leak in along the Main Wing Spare. Any suggestions on a way to stop this air leak? I already have aileron pushrod boots, which helped.
Thanks.
Ron
I believe the air comes around the spar, entering through the wing root. You should be able to remedy this by removing the wing root fairings and sealing around the spar with foam.
