Scotty G Well Known Member Sep 25, 2020 #1 Hi, gang, Where are you guys sourcing your cockpit mirrors? Thanks in advance. Scotty
Ironflight VAF Moderator / Line Boy Mentor Sep 25, 2020 #2 Autozone....I’d give you the model number, but that was fifteen years ago, and it has probably changed. Think outside the box!
A ArlingtonRV Well Known Member Sep 26, 2020 #3 Adjustable mirror from Amazon: https://www.amazon.com/gp/product/B001DKT0DO/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1 Mount from RVplasticparts.com https://www.rvplasticparts.com/product-page/small-mirror-mount
A Agent86 Member Sep 26, 2020 #4 I haven't fitted mine yet as I need to work on the mount point. They look like a good size to fit on the canopy bow. 2pcs-Slim-Car-Rear-View-Blind-Spot-Mirror-360-Rotating-Convex-Wide-Angle-Glass-Mirror
emsvitil Well Known Member Sep 26, 2020 #5 How about car backup cameras............ Then have a switch so you can see forward for taxiing
Scotty G Well Known Member Sep 27, 2020 #7 Those are pretty neat, Vince. Thanks. Problem is the RV-8 I’m buying has a Showplanes Fastback and side-tip canopy. So I went with these, which look to be easily adaptable: https://www.ebay.com/itm/Vans-RV-4-...rand=Unbranded&_trksid=p2332490.c100935.m2460 Thanks to everyone else for their help. Much appreciated.
Saville Well Known Member Sep 28, 2020 #8 vfrazier said: Formation mirrors Click to expand... Hi Vince, Do those formation mirrors pivot? If so hoe many axes? Or is it on a ball joint? Thanks
