The "measure it yourself" comment was not intended to be rude since the method to do so was described as an instructional aid. The original post appeared to need it.
Since you are prevented from measuring yourself, and are buying for only one single wire run, I would order not less than 24 feet.
12.5 feet from tip to center, 4 feet from spar to firewall, 3 feet up firewall, 3 feet to radio. Add something for insurance. That will provide enough for any route through the cabin that does not take unnecessary circuitous paths. You will have some left over, but it is better than the alternative.
