CharlieWaffles
Several of the FWF fittings on the lycoming and firewall are often 823 or 822 (45/90 degree fittings). Often there is a specific clocking that is needed to accomodate a hose.
Often it is impossible to get the fitting within the recommended torque range AND proper clocking. The approach I've taken is to get the fitting as close to the recommended torque and then adjust for clocking - something less torque, sometimes more. I am using Loctite 567 that should also help with any thread leakage.
Am I asking for trouble by not ensuring at least the minimum torque on these fittings even with a thread sealant?
What is the best way to go about fitting that needs a minimum torque and clocking to work?
