siclick33
Member
I am shortly going to be ordering some tools from Cleaveland Tools. Due to the cost of shipping to the UK I am looking at adding some of their RV accessories to the tool order. Which of the following bits would you recommend to use on a RV-8?
Tail light adapter ring
Rudder trim tab
Threaded tie down blocks (and tie down rings)
Flap rods
Rudder cable fairings
Jig brackets
Thanks.
Used most
I have several. Not the rudder tab or jig brackets.
Love those tie down blocks. I replaced mine and installed them so the block was flush with the skin. Reduces the stress on the skin when you tighten the hold down bolt.
