Just wondering if there is a trick in using the main squeezer, I bought one and still getting used to it but not very impressed so far. My main issue is that I feel a rather strong springy action in the lever. Best I can describe it, if the squeezer is held with the handles at 12:00 and wide open action would be at 3:00, you will start feeling the pressure building up between 2:00 to 1:00 and then eases off as the handle is coming together at 12:00. But as soon as I want to open it, the handle wants to jump (spring action) to open position which kicks the other handle to opposite side (let?s say 11:00) and this can cause my piece that is still between the yoke to bend if I am not careful.
Not sure if this was a good way of explaining it but I wonder if mine is defective or all work like that?
