"(a) Each person performing an annual or 100-hour inspection shall, before that inspection, remove or open all necessary inspection plates, access doors, fairing, and cowling. He shall thoroughly clean the aircraft and aircraft engine."
Part 43 app. "d" I believe, in the certified world.
At your stage, it would take very little time to wipe down the engine. Might as well keep it clean.
The RV at 500 hours gets a simple wipe down with a clean rag, not much to clean up. I have no pan under the RV.
The Bucker at 2300+ gets the full stoddard solvent treatment with a "wand" hooked up to compressed air. The Bucker is allowed to leak as she has worked hard for many hours. (Most of the leaks are not easily serviceable.) I keep a pan under the Bucker.
