If your asking about the hinges on the seat pan, yes. Also, you may consider not installing the rear most hinge. The Aero Classic seat has a 45* bend at the bottom where the hinge attaches. Causing the second from the rear to give the same leg length as using the aft hinge on the Vans seatback. Using the last hinge with the Aero Classic will cause a nearly vertical seatback.
