Brian has a Sam James cowl and cooling plenum. Search the forum for "james cowl" then Google it.
When you order your FwF kit delete the Van's cowl. There is very little cost difference between the two cowls.
One word of caution, they are a good bit more work than the stock setup.
Hi guys, can anyone tell me if the circular vents for the engine cowling (watch the pic) are an optional that should be selected when you purchase the kit, or is it a change that can be done after?
... It's just fiberglass.
Bear in mind that the primary reason for the round inlets is to make a simple interface for the plenum to connect to.
Buon giorno - benvenuti al mondo di Van's Aircraft.
To add to the above comments, the Sam James cowl needs little exterior finishing from the example I saw today - very smooth. But, in looking at speed and temperature data, with and without the Sam James plenum (sold by a different location in Florida), I have truly seen negligible differences. For me, it is a matter of aesthetics, with the SJ cowl much sexier looking, albeit at the price of more work (though I'm not at this stage yet, a builder today told me that the Van's baffle kit is wonderful and fits well with their cowl. With the SJ cowl, there will be many hours more work).
As an aside, there are a dozen or so RV builders in Italy. There is a Luca P not far from you, but don't know him and if he still has his flying RV. Not too far from Verona south of Milano near Lodi is Lucio Castrogiovanni, building an RV-7. I visit him every year - a great guy. Message me if you want his contact information.
Arrivaderci,
Carl
....the Sam James cowl needs little exterior finishing from the example I saw today - very smooth. But, in looking at speed and temperature data, with and without the Sam James plenum (sold by a different location in Florida), I have truly seen negligible differences. For me, it is a matter of aesthetics, with the SJ cowl much sexier looking, albeit at the price of more work....
