Look You-allll I was just kid-in
Look I love airplanes, anything mechanical and if it makes noise, burns fuel and especially fly?s I love it.
My "technically superior" comment was tongue in cheek because of the way the question was posed. I also have an engineering degree BTW so I won?t hold that against you.
5 things I don't like about auto engines:
Weight
Heat exchanger (seemed scabbed on under the cowl anyway they fit)
Performance: top speed and climb rate (sea level normal aspirated)
No hydraulic prop control
More system complexity
WEIGHT: Really as far as weight all you have to do is look at the scales: From my list and Dan's list:
http://www.rvproject.com/wab/
(2) Subie's: empty weights (lbs)
RV-9A 1213 lbs
RV-7A 1171 lbs
(2) Mazda: empty weight (lbs)
RV-6A 1170 lbs
RV-6 1095 lbs
(120) RVs and their average empty weight?s with fixed or c/s props, models (RV-4,6,6A,7,7A,8,8A,9A)
O-320..................1034 lbs
(I)O-360 (180HP)...1084 lbs
IO-360 (200HP)......1151 lbs
Let the numbers speak. Except for the one Mazda all the auto engines are near 1200 lbs! That is heavy. Mazda seems to have an edge on the Subie but was still 1100 lbs with a fixed prop. That is 30-75 lbs heaver than comparable RVs with O-320/O-360/fixed pitch props. Not bad but could be better. Of course who knows about paint, equipment, lights etc. Regardless weight is not an issue. Auto engines weigh more, no surprise.
For the record an (I)O-320/(I)O-360 weights vary from 240-280 lbs. The Lyc IO-360 (angle valve, counter weight crank, 200HP) is a heavy engine at 320-330 lbs , not 400 lbs or whatever. An (I)O-540 does weigh 360-375 lbs, and can put out 250-300hp continuously. Again real HP at the prop, not auto engine numbers at 8000 RPM. Dyno of an auto engine should be w/ PSRU and components used in airplane. Installed weight: remember your auto engine needs the PSRU, radiators, coolant, extra fuel pumps and batteries.
HEAT EXCHANGERS: When Van designs in integral cooling tunnels in the fuselage belly or a better way (less drag) to locate radiators is found auto engine installations will suffer more drag. Just throwing radiators in under the cowl with no baffles or diffusers is not ideal. To be fair the air-cooled engines have over 75 years or research funded by the government to reduce and optimize cooling drag in air-cooled aircraft engines. Last work from NASA was in the 70?s from funded work by the U of Mississippi on reduction of cooling drag in horizontally opposed air-cooled engines. The result is the round cowl inlets, pressure plenum benefit quantified and data on cowl exit design factors. There is info, which is relevant to radiators for water cooling in this report. This is where more work is needed for water cooled engines, but the airframes are designed for air-cooled engines. The work done on the P-51 is available from NACA (NASA's predecessor) may be of use. My point is the radiator installations are aerodynamically ugly.
PERFORMANCE: Well this is hard to prove but I?ll go the races. There have been a few fast Subies and Rotary engines, but by in large the Lycomings are going much fastest in the races. Tracy Crooks RV-4 has been getting faster of the years and he came in third in the general 160HP class at the Sun 100 race 2004. If he raced in the 180hp RV class he would have finished 6th. This is good, nice job, but remember Tracy has been screwing with this for years. Who knows how many RPMs he was turning?
http://www.aircraftspruce.com/sunfunraceresults1.php
Also the heads-up comparison Van did between two beautiful Powersport Rotary engine RVs and a 180hp RV showed they were right up there in speed, however the fuel burn of the rotary RV?s was large (see the last RVator). The powersport engines are highly modified 13B Mazda from Everett Hatches work. They also had nice custom cowls (James aircraft). The claim of 215hp for these highly modified Mazda engines only fly as fast as the 180hp RV. Is it cooling drag? Is it the extra weight? Don't get me wrong, but they burned huge fuel over the Lycoming for equiv speed. At least they performed well. They weighed about 70lbs more than the Lyc 180hp Lyc RV.
http://www.powersportaviation.com/
Also a rotary has 3 rotating parts and is nothing like a turbine, more like a two stroke engine. I know I fly turbines. The noise my be solved at cost of weight and drag but the design of the engine will always have a bit of fuel burn disadvantage. Also a side note and one thing I don't like is adding oil to the fuel. A minor issue but a hassle, about 3/4th qt of oil every fill-up. My Lyc takes a qt every 4-5 fill-ups (16 hours).
The real proof is in actual flight test against similar RV?s with Lycs. Auto engine performance is making head way. If the cooling drag and weight issues are addressed while adding reliable power you are on your way to a true alternative, which is better. However that is easier said than done and no guarantee it can be done. In the mean time Lycomings are getting roller cams, electronic ignition, composite oil pans, more manufactures AND getting cheeper (O-360 new, all accessories $18,000). OH NO
HYDRALIC PROP CONTROL: PSRUs do not have hydraulic prop control**. I don?t hate electric props or MT, but they just are not as good as hydraulic control. It is a compromise not a preferred design. Also MT props cost too much. Electric MT props are "9 Large". I just can?t imagine having to ship my prop to and from Germany when there are lots of companies in the US that make all kinds of metal and composite props, 2 and 3 blades. (Like the fastest prop, a 2-bladed blended Hartzell for $5.5K that can be worked on by every prop shop.)
The PSRU already weighs enough. To add the gov drive would add weight, cost and complexity. Needless to say the Lycoming was designed from the drawing board to use a hydraulic prop and it's weight includes this capability. No PSRU needed with direct drive.
http://www.mistral-engines.com/ has a PSRU with prop control, the story is they will sell them for $6.5K? There goes some of the cost advantage of a homegrown Mazda installation.)
Subie and the Mazda are hurt by fixed pitch props may be more than a Lycoming because they need RPM to make power. Remember an O-360 is almost
(6) liters. How many liters is a Subie?
(3) liter. No wonder there is less vibrations the pistons are small. Lycoming pistons are 5? in diameter. Of course the higher RPM?s auto engines need means a PSRU. A necessarily evil I guess, but the direct drive Lyc is elegant in it's simplicity. By the way gear drives are not new. Lycoming and Continental have had geared engines for decades.
SYSTEM COMPLEXITY:More batteries, more alternators, more pumps, more pipes, more heat exchanges and complete dependance on electrical power and electronics. Yes they are work arounds but it's not KISS.
In closing I love all planes and engines, but I don?t have the time to engineer and play with an installation of my own design. Of the off the shelf Subie kits, nice but not optimized and cost too much, way too much. The off the shelf Rotary (powersport) is out of production and was a little spendy but very nice. Hope powersport comes back. Do it yourself Rotary? Nice, get a PSRU with hydraulic prop control, reduce weight (titanium exhaust pipes) and Van offers an option to install radiators in firewall or belly. Cost? Performance better than a Lycoming? There will be very little profit in FWF kits in a small market and cost will be high, and they will be competing against Lycoming, like it or not. The best auto engine installations and designs are going to be custom and limited to individual efforts of a few talented folks for a time to come.
My criticism is constructive and some what factual and correct I hope. No offense intended. The Lycoming is not manna from heaven, but it is not bad if you respect it's limitations: Keep CHT below 400F, oil temp 190-210F, use proper leaning technique, don't abuse it with fast throttle changes and shock cooling, fly often and change the oil.
The alleged benefit of auto engines in maintenance and overhaul is overstated. Your going to have to wait a long time for this to pay-off. A Lycoming can go 10-15-20 years without overhaul if limits are observed. I should know I have gone to past TBO twice with no problems. You will have to change the oil less in a Subie but that is chump change. No one has flown a large turbo Subie for 2000 hours or 20 years, so all the maintenance talk is really a guess. How long is that PSRU going to last. If your engine is fine but the wind maker takes a dump, you are screwed.
The auto engines have less delicate temp issues and less "mass inertia" of parts. (Yes I know "rotary engines go round", my family owned a RX2 and RX3 in the 70's.) Water cooling is great, but in a plane it's a double edge sword. I think a Lycoming with water cooling would be great.
Cool Jugs! They are cool
![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
but they cost more and add weight; Also, you than have to deal with the radiator installation design issues. Air cooled sucks (or is it blows) but it is well established and works.
Cheers George MSME, ATP, CFI
() Corrected thanks MC
