Jess Meyers
Member
Any one ready to try Chevrolet V-6's
You know about "Belted Power"? They have stuffed many a V-6 into RV's. Check their site. GJess Meyers said:Any one ready to try Chevrolet V-6's
If you have to ask how much it weighs you may not want the answer.djvdb63 said:Jess...
What is the empty weight of N9267Y, your RV-6A demonstrator?
Dan Vandenberg
Dan nice write up. I agree weight is an issue, and have followed their work for a long time as well. For all you who want to read more they have articles on their web site. Look forward to Jess telling us more specifics about empty weight and performance. What would be great is a fly off side by side to a O320 RV. This was done with the Rotary and Eggenfellner RV's against Van's factory planes. That is the only way to do it. Jess interested in a fly off?djvdb63 said:George...FWIW...I know all about Mr Meyers. Dan
George, the Egg Sub's could use a FP prop too, but it would compromise performance.......Gale DeRosier around St. Louis. According the Gale, he cruises at 170 mph. Dan
Jess, interesting.Jess Meyers said:Dan, thanks for the interest, The aluminum heads will net a 40 lb savings. But the price is $2000.00 just for the heads...........
The prop came in at 25 lbs all up including the power pack that is mounted any where that's convient. It is a hydraulic prop that does not require a hollow or oil shaft.................
Thanks also please, do you have any info? And more info on the hydraylic prop on solid crank/reduction drive. Thankscjensen said:Jess,
Any info on the Aluminum block? Cost? Weight savings?
pierre smith said:Take your V-6 or Egg to the Bahamas and break down......who do you ask to fix it? Take your Lyc........seewhatamean?
Not trying to steal Jess's thunder. He is the man for BeltedAirPower. However I have seen the ad for Robinson VB power in the EAA mag. http://www.v8aircraft.com/jrdalton said:I'm building a -10 and am interested in a GM engine - if it works that is . . .
What are your thoughts about an engine for the -10?
Jeff
[email protected]
Jess Meyers said:The all alloy version on an RV is too light
cawmd82 said:......maybe another emotion would be provoked----terror, fear, nausea, trembling, etc
]/QUOTE]
Yes, and the reason why my XJS has a Chevy 350 in it!![]()
Hey dan that is cool interesting stuff. I used to strain gage stuff back in the day for structural analysis and certification. However I just want to point out the Belted Air Power guys of course use a Belt, which kind of takes the torsional harmonics out of the picture, which is why it's so elegant. Analytically the drive shaft is so stiff it is not critical and the belt is such and effective damper that harmonics are not critical.DanH said:Back when you started, the only practical way to test PSRU's was to fly them and see what fails. You could calculate torsional predictions if so inclined, engineering stiffness and inertia values to minimize vibratory torque values at the resonant intersections. However, verifying the predictions by measuring the results with the running system would have been difficult for a small developer. The problem was (and remains) getting the data off the rotating shaft. In the old days that meant sliprings or analog radio, and both were bulky, noisy, and expensive. Dan Horton
Dan, I would really like to hear more about this, if you have further details.DanH said:<<Eggenfellner also evaluated theirs in conjunction with MT I believe.>>
Again, anything published? BTW, I watched a guy remove a trashed Egg gearbox yesterday.
DanH said:Re the Egg box: The propshaft had moved forward, extending from the case perhaps an additional 1/4". I don't know why, as I know nothing about the internal construction of the gearbox.
In addition, I observed a small quantity of fine, shiny metalic debris on the face of the pilot bearing seal when I looked into the splined hole in the center of the flywheel assembly. The owner did not remove the flywheel while I was there, so I have no idea if the metalic debris actually indicated a problem. I understand there is some sort of spring-based soft element in the flywheel center.
The owner said this was the second failure for this gearbox.
Dan
Hey Dan don't be sorry, I am always learning new stuff. I only got a quick study of your comments, but I'll look into it and get back to you. I do understand that you can have harmonics even with a belt in there. I did make some assumptions based on inspection of the Belted Air power Unit, which may not be correct. My assumption is the shafts, belt, bearing supports and frame are so stiff (overkill), with some belt damping, it would not be torsion ally critical. Like you say you don't know unless you measure it. I can't argue with that. I was not making a statement about any drive using a belt. I agree it is not a magic wand, just one part.DanH said:<<..... use a Belt, which kind of takes the torsional harmonics out of the picture, which is why it's so elegant. Analytically the drive shaft is so stiff it is not critical and the belt is such and effective damper that harmonics are not critical.>>
I'm sorry George, but the above is quite incorrect in several ways. Dan Horton
Torsional vibration threw the shaft off? The shaft on the Belted Air Power is supported at both ends and throwing the shaft is hard to envision; I'll also get back to you when I read the article. There's had to be a LOT more going on to throw a shaft off, more than just the belt drive. I suspect it was a light duty design that did not have proper supports.Rotary10-RV said:They had it all, belt, drive shaft, 2-cycle engine rubber mounted. There were several interesting failure modes. One caused a stub drive shaft to be thrown thru a wall from the test bench. Bill Jepson
