N546RV
OK, so I bungled up a rivet big time while putting my left elevator together. The hole is now oversize and a bit elongated; I'm trying to figure out the best way to repair and move on.
My first thought was to go up to a -5 solid rivet, but considering that the somewhat tight location had already contributed to the current situation, I'm thinking I'm likely to have the same difficulties, or worse, trying to set a -5 in there. (location is the two holes between the counterweight rib flange and spar web)
Hence why I'm leaning towards putting a Cherrymax rivet in here instead. My understanding is that, properly set, a Cherrymax is a perfectly acceptable substitute for a solid rivet...sound about right?
Next question: Am I likely to need more of these things as the build progresses? I'm trying to decide between making a run to Spruce on Saturday (two-hour round trip) or just trying to scrounge a handful from the local builder population or something. Maybe I could go to the 690 breakfast Saturday morning and carry around a "will work for CR3213-5-2 blind rivets) sign...but if it's worth it to stock up, I'll go ahead and spring for a supply from Spruce. (I'd like to think I won't be needing a lot of -5 rivets in the future, but I dunno...)
Finally...Cherrymax rivets can be set with a regular old blind rivet gun, right? So long as I'm careful?
