hecilopter
Not being a chemical engineer, just thought I would ask a question that an engineer could answer.
1) If I had 10 gallons of 93 octane mogas with 10% ethanol would I have 9 gallons of gasoline and 1 gallon of ethanol?
2) If ethanol absorbs water, and I added 1 gallon of water to the 10 gallons of ethanol enhanced mogas above, would I get 9 gallons of gasoline floating on 2 gallons of an ethanol/water mixture?
3) If so, could I now drain the 2 gallons (should be visible as clear) from the bottom of the resulting mixture and have 9 gallons of "pure" (ethanol and water free) gasoline?
4) And finally, if somehow miraculously this all worked, would I still have a 93 octane rated gasoline leftover?
Sounds too simple but just wanted to ask.
