Chris,
Do you have any pictures/part numbers of what you used?
Thanks!!
Ryan:
Here are some photos that may help. I don't have a part number. As I mentioned in a previous post, you can get these from a good hardware store in the Fastener department. Look for number 6 and number 8 size. You can usually find them sold by the piece and in boxes of 100.
The first photo below shows the screws. They are stainless and come in a variety of sizes and lengths. The ones shown are #8. I used mostly #8 of 3/8 inch length plus a few of 1/2 inch length. I used a few #6 in the instrument panel as determined by the instrument (EI gauges for example). A shorter screw means fewer turns so use 3/8" as much as possible. (I had started with 1/2 inch since Van's screws are 1/2 inch, but found that to be longer than needed in most places.) The screwdriver-like tool shown has a hex-shaped shaft plus the tip is rounded so that you can still turn the screw from an angle. This really helps when the screw is next to the sidewall or longeron. There is also a little stubby looking insert which is a hex insert that can be used in a small ratchet tool or power drill. You can find these at Sears, Lowes, HD, etc.
![](/community/proxy.php?image=http%3A%2F%2Fimg291.imageshack.us%2Fimg291%2F3835%2Fno8hexscrewsanddriversjw0.th.jpg&hash=397a7ccdd89053710b494ceef629afde)
Click on photo to enlarge
The next few photos show where I used these screws. I only used them in the INTERIOR of the aircraft. They are perfect for places that need to be removed each year for the condition inspection (side panels, floor pieces, baggage compartment) and to secure the panel instruments as shown in the close up. I also used them on the covers near the gear towers (RV-8) such as where the fuel valve to switch tanks is located.
![](/community/proxy.php?image=http%3A%2F%2Fimg239.imageshack.us%2Fimg239%2F6141%2Fpanelcloseupoa8.th.jpg&hash=faf2d9ad051f059872daf5c447623331)
![](/community/proxy.php?image=http%3A%2F%2Fimg239.imageshack.us%2Fimages%2Fthpix.gif&hash=c54079a3e58410da5e460e0e453aa9e8)
I
nstruments held in place with hex screws
![](/community/proxy.php?image=http%3A%2F%2Fimg186.imageshack.us%2Fimg186%2F387%2Ffuelpaneluz3.th.jpg&hash=ce7033c237f52aa81378f1e27d116a41)
Lower left panel behind gear tower - instrument and panel are held by hex screws
![](/community/proxy.php?image=http%3A%2F%2Fimg186.imageshack.us%2Fimg186%2F1152%2Fsidepanelnm4.th.jpg&hash=2220dcbe3785a369887ad4dd6e1f9eb6)
Rear seat side panels held on by hex screws for easy removal
I like these screws in place of phillips head screws because they provide a good gripping surface for the tool with less likelihood of rounding off the edges. These can be removed and reinstalled with a battery powered drill or ratcheting screwdriver. Yes, you can SNAP OFF THE HEAD of one if you force it into a nutplate. And since it's stainless, it's a bear to remove when this happens. I only did this once.
For the interior places where I used these screws, I did run a tap through the nutplate first. Shame on me, but I haven't had a single one back out even a little in 275+ hours. And the areas where I did this are not structural.
You'll notice these screws are not countersunk. They stick up about a 1/4 inch from the surface. No big deal in my opinion.
So that's my approach. Hope it helps or gives you food for thought.
Chris
