S stan albright Member Dec 6, 2015 #1 Does any one know whats involved in changing short gear on a 4 to longer gear and what that mite cost
n82rb Well Known Member Dec 7, 2015 #2 It requires a new engine mount and the new gear legs. Also, the intersection fairings will no longer fit. Also because of the geometry change the wheel pants will also have to be re fitted. Bob burns Rv-4 n82rb
AX-O Well Known Member Dec 7, 2015 #3 and the worst part, two new holes on the firewall for the center bolts. They don't match the old holes.
C cguarino Well Known Member Dec 8, 2015 #5 There is a fix AX-O said: and the worst part, two new holes on the firewall for the center bolts. They don't match the old holes. Click to expand... Contact Vans. They have an engineered fix for the firewall holes. I swapped my gear and I'm glad I did. Good luck.
