Do you really want a graph or just the limits? The CG limits do not vary with weight. The aft limit is constrained for aerobatic flight but still doesn't change with weight.
A Google search got the following:
CG Range, Normal operations: 68.7? to 76.8? aft of datum
CG Range, aerobatic category: 68.7" to 75.37" aft of datum
Datum Point is: a point 60.0? forward of the leading edge of the wing
