Hi All, isometric view at drawing 11 shows two AN4 bolts that connect the rear and forward center section with some tubing acting as spacer in between. funny thing is that the 1/4" holes on the left side match perfectly but not on the right side. The offset of the two right holes (rear and forward) is around 1/16" and there is no way you can get a bolt through. any idea what to do here?
it's the center section after all so i don't want to mess with it.
Cheers
Kay
Cheers
Kay
