1bigdog
I'm trying to finalizing some details on a center console and was hoping to nail down some measurements. In particular I was hoping to find out the position of the bulkhead bracing. I don't have a sample throttle or mixture cable to work from. Does anyone have measurements on where the bulkhead bracing threaded area is in relation to the throttle quadrant? I'm assuming there is some variability with the threaded rod, clevis and rod end; could I also get your mix and throttle cable lengths if you are using an IO-320-D1A.
Thanks all
