3-Blade Catto for ~7 Years
I confirm all the things stated previously about the Catto prop. Some things about the Catto prop many people don't think about: (1) treated as a 'wood' prop if you have a prop strike (i.e., dial check the crank shaft flange and if 'OK' only other thing to do is check accessory gear box (and a new prop of course)); (2) Catto props are tough - even if they do strike the ground you will only bust off at most about 6 inches from the tip (you can imply from that that the blade is strong and unlikely to ever separate in flight), and (3) the 3 blade prop serves as a nice cradle to support your airplane (without harming the wing tips in anyway) if you elect not use your tail wheel for support. AND, after you bust one up, they make an interesting conversation piece when mounted on the wall!
