......... I have a carbureted, angle valve O-320.
Ron Voss
N642R
200 hp O-360, 3 blade Catto. Around 2200 rpm or so at lift off. Never measured max but it is over 2700 rpm
Checked today and it was 2250 at lift-off.
Dale, should that improve your cruise speed? I suspect that I need more pitch on mine after the engine rebuild but don't know if it is worth the expense and downtime.
2640 is the max RPM I've ever seen on my Catto 66 x 76 with my Aerosport IO-360. On takeoff it makes about 2220.
7A, SJ cowl, plenum & pants, 180 hp Superior, Catto 3-blade, repitched to match my performance.
climb @ 110-115 KIAS =>2150 approx
WOT @8000' DenAlt = 2750-2770 (175 kts KTAS)
Craig says normal spread between these should be about 500 rpm.
I'm here. Just really busy. Sorry. My idle RPM is about 650. Static is around 2250. Max RPM st WOT/8000' is 2750. On landing approach, I have no idea. I'm looking outside.Hello Catto Lovers,
Let's look and the idle and landing pulled throttle RPM's. IOW's what RPM do you see sitting at pulled idle with engine at takeoff temp? Then what RPM do you see on final windmilling throttle pulled all the way back in landing configuration say 25-30 degrees flaps? I'm going to back off the idle on my plane a little and just looking for numbers for a spread sheet to work with to find that sweet spot.
I PM'ed Mel on this issue as we have a close engine/prop setup, but I guess he's on vacation again.![]()
Hey Mel,
I figured you were back on a boat cruising to some other part of the world.
Thanks for the numbers!
We've matched numbers over the last 3 years. Same pitch, I'm getting 2640-80 rpm.
My idle rpm is 420 and when we lowered it it really helped control descent on final. Don't know what rpm is on final--never really looked. I get 2180 on takeoff and 2780 WOT at 8000' DA. Speed at that altitude is 192 mph, somewhat better than Van's projections for a 160 hp 9A. It is faster higher up, but I haven't really nailed that down exactly. Close to 200, but not sure. I am surprised that it is faster higher up, but Craig wasn't. P-Mag's seem to make the difference up high, but I can't be sure.
Bob Kelly
Dan and Scott, I'm still doing my phase 1 and don't have wheel pants or gear leg fairings. I'm getting about 2570 max RPM, but I figured it was just because my airplane is draggy. Do you think it's possible that you're not getting full RPM's due to drag from something?
You will not get full RPMs unit the plane is cleaned up.
Hi Bob,
It the 420 RPM idle with the Catto Prop, have you ever had the engine want to die on final? I have a friend that went from a Sensenich to a two blade Catto and this happened to him. I take the difference in 42 lbs spinning and 18lbs spinning...??? It did get his attention.![]()
