Dayton,
You got me on the top end--with a 320 yet--now that is embarrassing!!
I am also thinking about a little more pitch to get my cruise rpms down somewhat--what pitch did you end up with and do you have Craig's newer designed prop tips or the older (pre-2006) design??
Dan,
Thinking more about the EI, high power runs, and rpm I would have to say that the only benefit would be the hotter spark on the EI and I don't know how much difference that would make at high power. As you are probably aware, most EI's, including the LS, run close to the mag advance when you are running high power/high mp settings. At low power, like my cruise settings of 60-66% where I am only running around 20-21 inches mp with the fp, my EI advance is up around 33-34 degrees. I am convinced that this advance, coupled with the hotter spark is what allows many of us with carbs to cruise smoothly lop. However, we have far more qualified EI specialists on this site who might be able to offer more details.
db
