drone_pilot
I have a new Catto 3 blade prop and got the spacer, crush plate, bolts, and spinner with it. I noticed that the prop bolts are not drilled for safety wire. Is this normal?
There should be two sets of bolts. The bolts that attach the spacer and ring gear to the crankshaft are not safety wired. The bolts that attach the prop to the spacer are safety wired. Those bolts should be drilled.
Michael
