Note to moderator - please leave this in the general discussion section, as the area I'm inquiring about is identical on the RV7/7A and the RV-9/9A.
In preparing my center fuse I didn't double-check the plans carefully enough, and forgot where it said not to dimple the 4 locations at the interesection of the 904A bulkhead and the stiffeners.
What I did was to countersink *all* the holes along the lower flanges of the 904A and 904B bulkheads, where the 976 bottom skin will be rivited (and I dimpled all the corresponding holes in the 976). The note about not dimpling those 4 locations mentioned above leads me to wonder whether the intent was that I should have *dimpled* all the other holes in the lower flanges of the 904A and 904B, rather than countersink as i did (the thickness of the material suggested to me that I countersink all thes holes, but the note about those 4 locations confuses me).
One concern I have is those double-flush rivets in the outboard 5 rivets on each side of the 927-904A joint. Because I have already countersunk these holes in the 904A from the bottom, when I countersink the other side for the double-flush rivet, this will leave minimal material in the 904A around those holes and enlarge the holes somewhat.
Do I have a problem, and if so, what should I do to correct it?
