The reason you probably will not be able to find one is the price of a rebuilt carb using that one as a core exchange just doesn't justify an overhaul of yours. Unless you have a specific problem ie acel.pump or bad float the labor and parts for total overhaul will easily exceed the factory rebuild price. The small carbs are not rocket sciencee youmight be able to overhaul yours for parts if you do it yourself. But good luck in you search. Cost what it's worth.
