JCN247DE
Hello group,
For those flying carb engines - how did you secure the carb nuts - just lock washer or drilled the nuts for safety wire?
Also, do you torque the exhaust to 100 - 140 in/lbs as with other AN5 bolt apps? I did this and the star lock washers are smashed. Should I use a different lock washer style for the exhaust?
Thanks all,
Jeff
Carb Nuts/saftey Wire
You Can Purchase The Screws With A Safety Wire Hole Alread In Them. If You Are Making Reference To The Carb Assembly Then Use The Bendable Lock Washer Specific For This Use.
I used hardened socket head screws and drilled them for safety wire.
The socket heads are easier the drill than the hex.
my 2 cents
cary r
