Hello, I'm building my first RV and in the later stages of assembly, specifically the filtered airbox for my 0-360. My question is that on every carburated aircraft I've ever owned they had a dedicated carb heat source. It appears to me that the FAB for my RV-7 uses an alternate air source that pulls air in from inside the cowling. Has anyone used this system in actual carb ice situations and if so how does it work vs an actual carb heat system?
Thank you
Thank you
