cjohngraham
Member
I have a 7A with a O-360-A1D. The nose gear leg fairing rides on the underside of the carb air box. We heated up the box and put a dent in it to accommodate the gear leg, but though the gear leg has adequate clearance, the fairing "free floats" at its upper end and rubs on the box. So far this is a cosmetic issue--just some paint worn off, but has anyone found a better solution?
