I've pretty much decided to use a graphical engine monitor: the ACS AF-2500 or Dynon EMS-D10. Now, before I order the wing kit, is there any reason I should get capacitive sensors vice the traditional float (resistive) fuel level sensors? I believe both will work with either choice. But I may have to use an additional adaptor for the capacitive sensors, correct?
I will not be installing a flop tube, were it to matter in this case.
Regards and happy to be about to restart construction.
