Badia358
Active Member
Has anyone installed a capacitance fuel sender into an already completed fuel tank/flying RV-6A that has a Dynon Skyview system installed? I would like to move away from the resistive senders in the tank now.
If yes, what capacitance fuel sender did you install?
Thank you...
These are going to be very difficult to install in the tank after it's been closed up, you'll have to cut holes in the rear baffle for access. Are you sure it's worth the effort?
Vans no longer sells the capacitance fuel senders but a VAF member here was going to make some for himself and sell to others that are interested.
A quick search found him.
Sounds like to much work for an already flying airplane. Thank you..
After more research, I've discovered that the calibration of capacitance probes is highly sensitive to the types of fuel in the tank - gasoline(gasohol?), 100LL, Swift Fuel - all will have different calibrations for accurate fuel level.
I keep reading this as a drawback to the capacitive senders, but how often are most RV pilots switching fuel types? Honest question, I'm a 99% builder 1% flyer at this point and legitimately don't know.
I believe the switching fuel issue is mostly with pilots that burn mogas. You have auto fuel at home, but usually have to burn 100LL when buying fuel away. That makes an unknown mix for awhile that burns fine, but doesn't measure accurately.
Haven't built the RV yet...but familiar with mogas in my TriPacer!
