I just finished sealing and pressure testing the first fuel tank and it looks like the only leak is through the BNC connector for the capacitive fuel sender. I've seen note in other build logs that fuel can wick through this connector, so I made sure to cover the back side of the connector in the tank well. The leak is small, I pressurized the tank to about 25" h2o and sprayed with soapy water to find it, small slow bubbles. Could this be air entering the wire at the terminal end and traveling through the length of the wire? Is this something that I need to open the tank to correct?
Scott
Scott
