I'm hooking up the vans capacitance fuel probes to Garmin GEA-24 with the EI P-300C. I have 2 questions. The P-300C has 2 ring terminals to hook to the tank. Am I to cut them off and attach a BNC? Also what is the routing of the wiring thru the skin? Can I drill a 3rd hole for the wire and use a grommet as I don't want the wire going thru same hole as fuel and vent lines?
Jay
Jay
