I've been trimming my canopy per the threads and websites on the subject- starting at the front and lowering it on the windshield bow keeping it contoured to the skin. As the canopy lowered onto the bow spacer (sika plans), I started trimming the sides and rear. As the sides came up and I was able to clamp them to the frame, I found that closing the large 3/4" gap at the rear caused the "corners" at the front to pop up about 1/4 inch...
. This makes sense if you have that foresight thing which I'm not gifted with.
Anyway, now my careful fit around the front is no more. Should I just press on and make the transverse cut and worry about it later when the windscreen is attached? At this point I'm not sure there is much else to do.
Any insights will be appreciated.
Jerald King
RV8
Tucson
Jerald King
RV8
Tucson
