rv9aviator
Does the bottom of the side canopy skirt ride along the top of the fuselage and just clear when fully closed? I had it in my head it went down over the sides of the fuselage by an inch or so, but I can see it would hit hard when closing part way because the skirt is narrower at the front. I am concerned about what the fit will look like when I attach the windscreen if I do the side skirts before the windscreen is installed. Would I be better off going ahead and getting the windscreen on now and then fit the canopy skirt? I glued the canopy on and will make the side and aft canopy skirts out of fiberglass.
