Canopy Sensor Data
Not sure if the HDX system is completely different than the Skyview touch but, in my system I have the canopy switch send a signal, open or closed, to Skyview. Depending on the condition, it shows a red or green circle labeled "Canopy" on the Skyview display. The configuration file is needed to create an audible warning when engine RPM exceeds 1500, or any other RPM you choose, with the canopy latch opened.
The switch and the file are two separate components.
