rv9aviator
I am struggling with understanding how to properly fit the canopy frame to the fuselage. From what I've read I am supposed to first get the lower square tubes to fit just inside the shape of the fuselage all the way from the front to be back of the tube. This makes sense so the canopy will follow the same lines and skirt will fit nicely against the outside skin. After I do this I drill a couple of holes in the tracks to locate them so the rollers will run smooth as you move the canopy back and forth. This part is done. Now am I supposed to squeeze the frame sides in 3/8 to 1/2 inch more before I attach the canopy so when it springs out the canopy will come back to somewhere close to where I had it when it worked in the tracks, or do I pull the sides in the 3/8 -1/2 inch with duck tape and simply hold it there while installing the canopy and then when I take the tape off it will spring back the same amount? I have studied other builders websites on this until I'm blue in the face. It was a nasty job getting it to fit as well as it does now and I really hate to start bending it again for fear it won't come back where it belongs.
I have another issue while I'm begging. The rear small dia. bows on the canopy are nowhere near flush with the aft skin. When I lay a straight edge on the aft skin I have about 1/16 gap at the top center but around the curved sides the bows are about 3/8 inch lower than the aft skin when you lay a stright edge on the skin. There is no way to fix this except to cut the tubes and weld in a piece of tubing and reshape the curve which will be a BIG ordeal. Any thoughts?
