Psyching myself up to tackle the canopy, and I have a question regarding section 34-05, detail A-A, and B-B. They call out a nominal spacing between the side of the C-1201 canopy, and the side rails of the WD-1219 canopy frame of 1/8". On first fitting, the canopy is almost a perfect fit everywhere, but it sits right on the side rails. Looks great so far. Should I space it to provide the 1/8" called out, or will it be ok to fit it contacting the side rails? I'm worried that the excellent fit everywhere else may be affected by shimming the bottom of the canopy. I know the canopy fitting process causes an undue amount of heartache among builders, but after all it is a one shot only deal, so I want as much info as possible before reaching 'the point of no return'.![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Regards DaveH
120485
Regards DaveH
120485
