On the project I bought (trying to deflect blame) the fuselage is 1/16" or so fatter than the canopy. I figured I could just off set the holes on the roll bar a bit and it would pull the fuse sides in the required amount. But when I checked carefully I found that the roll bar (A-frame thingy) had much more spring than the fuselage. So I figured I would get a ratchet strap or 2 and try to squeeze the sides inward to improve the fit. Any of you ever heard of something this desperate? Am I out of my mind? I really want a good fit since it is so visible. Any other suggestions besides OCD therapy?
